Hi guys
As you may probably know we can open an IdiagramElement from the current opening project using this way :
ApplicationManager.instance().getDiagramManager().openDiagramElement(IdiagramElement);
This works for me when i try to open an element from current opening project but it fails when i try to open an IdiagramElement from another project of my workspace
Please consider that i have read the IdiagramElement from the source project before and i have access to its object
This is my code :
// first i check if the element is inside current opening project
if (current opening project contains element) {
else{
// ask user to first open the project that contains that IDiagramElement (assume user knows what project he should open)
ApplicationManager.instance().getProjectManager().openProject();
// then open the element using same way as before
=> here is where the problem occurs .When the program reach to this point the Visual Paradigm will open the project that contains that element but i don't open the diagram that contains this shape ( it will stock on the project browser)
please also notice that i'm sure that i open the correct project (project that contains that IdiagramElement)
And here is the exception :
[2020/08/15 15:49:43] [warning] java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at v.deo.ajr.ms_(:362)
at v.avd.cg.a(:1766)
at v.avd.cg.a(:1943)
at v.avd.cg.b(:1893)
at v.avd.bd.a(:278)
at v.avd.bd.a(:270)
at v.avd.acc.a(:9875)
at v.avd.acc.a(:9829)
at v.avd.acc.a(:9818)
at v.avd.ahx.a(:81)
at v.cmc.rr.a(:890)
at v.beg.j.openDiagramElement(:115)
at ...
at java.desktop/java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.desktop/java.awt.Component.processMouseEvent(Unknown Source)
at java.desktop/javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.desktop/java.awt.Component.processEvent(Unknown Source)
at java.desktop/java.awt.Container.processEvent(Unknown Source)
at java.desktop/java.awt.Component.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Container.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Component.dispatchEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.desktop/java.awt.Window.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue.access$500(Unknown Source)
at java.desktop/java.awt.EventQueue$3.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.NullPointerException
at v.deo.ady.<init>(:5774)
at v.deo.bb.<init>(:17)
at v.deo.bc.<init>(:9)
at v.dfn.yj.<init>(:82)
at v.dfn.uk.<init>(:2179)
at v.dfn.wc.<init>(:80)
