Hi all,
I’ve created a use case diagram and have extended a use case which results in an ‘extension points’ section as shown in the attached diagram (top image). I’d like to keep this section but the text underneath overlaps the use case oval.
Is there a way to vertically shift the extension points section upwards without changing the oval size itself? (bottom image created in paint is the desired outcome).
I’ve tried the different settings but can’t find a way to move the extension points section independently.
Thank you,
Julian
