I have this message when executing install_service.bat, to install as a service. What can I do about it?
D:\VPServer\scripts>echo off
Installing the service ‘VPServer’ …
Using CATALINA_HOME: D:\VPServer\webserver
Using CATALINA_BASE: D:\VPServer\webserver
Using JRE_HOME (default): D:\VPServer\webserver\bin…\jre
Using JAVA_HOME: C:\jdk1.7.0_11
Using JVM: D:\VPServer\webserver\bin…\jre\bin\server\jvm.dll
Failed installing ‘VPServer’ service
Appuyez sur une touche pour continuer…
Sorry I should have provided this important information
It is a win 2008 R2 SP1 64bit server and I use the 64bit jdk.
I’m able to start the server and use a client with a floating licence.
Now I would like to configure a service on the server so I don’t have to manually start it.
I didn’t see anything in the event log of the system. I don’t know where to start to investigate.
Any idea would be appreciate
One more question, may I know you are using a 32 bit deployment of the VP Server? or the 64 bit deployment? You can find this information from the file name of the VP Server you downloaded.
Can you try right click on the command prompt shortcut and select Run as administrator, then change directory to scripts folder of VP Server to execute the install_service.bat to see is it works?
