I installed the community edition of VPUML for Eclipse.
I am using Eclipse 3.0 on Windows 2000 Professional.
Upon starting the same, I get a Fatal Application Error saying that
"Unable to Launch the Application"
Unable to locate the applications ‘main’ class.
The class ‘sderunner.SDERunner’ must be a public class or must have
a ‘public static void main(String [])’ method. LAX
Upon opening the Details box, I see the following:
java.lang.UnsupportedClassVersionError: s/z (Unsupported major.minor version 48.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:486)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:111)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:248)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:297)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:286)
at java.lang.ClassLoader.loadClass(ClassLoader.java:253)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:313)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:120)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
When I run SDE Community Edition for Visual Studio.NET, I am getting SDERunner.exe, Application has generated an exception that could not be handled. If someone knows how to rectify this, please let me know
I got exactly the same problem reported by bandupatil.
I installed SDE CE for IntelliJ IDEA (version 4.5) and I’ve j2sdk1.4.2_04 installed and working.
There are no SDE context menus in the IntelliJ IDE, too.
OTOH the standalone UML application (CE) runs without any problem.
[quote=bandupatil]I installed the community edition of VPUML for Eclipse.
Thank you for your message. I notice that your post was made on 2004. Could you please try again with our latest release? I guess that the problem is solved already.
