I’m breaking up a class diagram into multiple class diagrams. Some of the classes appear as base classes across multiple diagrams; for each base class, only one diagram holds the master view and everything else is an auxiliary view. I want Doc Composer to display the proper image for each class diagram but I don’t want it to document the auxiliary view classes as it iterates through the diagram.
In short, documentation for a class should appear only if the diagram being documented is the master view for that class. Is there a way to do this?
Hi. I’m becoming intimately familiar with template customization (I really like it, and have at least one suggestion I will be posting shortly). However, I’m not seeing the code you posted. All I see is “…”.
