Hello!
I can generate an Activity Diagram from a Flow of Events of a Use Case. But how can I specify the Flow of Events of a Sub Diagram and then automatically generate that Sub Diagram?
Hello!
Hi junkw,
Thank you for your post. Unfortunately, I do not understand what you meant by to specify the flow of events of a sub diagram. What type of sub diagram do you mean? Do you mean how to make the activity diagram produced from use case become a sub-diagram of use case? Actually, this is already the current behavior.
I believe this question is adequate to the topic.
Is there a way to automatically generate the Sequence Diagram from the Use Case flow of events?
