I need to use Cambria Regular 11 font for all the text on a sequence diagram. However, every time I create or edit a Note in a sequence diagram, it uses the built-in default font. I have tried every combination of the Set as Default option from the Styles and Formatting → Formats… pop-up, but nothing works. My preferred font is used for all other objects on the diagram. Is this a bug, or am I missing a menu option?
Unlike normal element the Note is edit in HTML by default. You can configure default font for HTML content under Window > Project Options > Diagramming > Environment > Default HTML Description Font. Feel free to contact me for any questions.
I checked, and I had already set it to Cambria 11. Any other places I can check?
Do you mean you performed similar configuration as attached video but still not working? If so then would you please send me a screenshot of the Help > About dialog of your VP application so that I can see which version and build you using?
