I create a entities relationship diagram. I need to generate a java code and a class diagram. I read the tutorial https://www.visual-paradigm.com/tutorials/generatecdfromerd.jsp and pressed the button Tools > Hibernate > Synchronize to Class Diagram. There was a dialogue as in the tutorial and pressed Ok. The program turned into a black square and hung for 30 minutes. How do I know what the problem is? The entity diagram is not very large. My version 14.2.
Is the problem reproducible? Can you test with a simple ERD with single entity?
If you can reproducible the problem, would you mind send your project file to support-team@visual-paradigm.com and include the link to this post (https://forums.visual-paradigm.com/t/generate-class-diagram-from-erd-not-working/13763
) in the Email?
Sent a letter
I update my visual paradigm to 14.2 Build sp1_20180201 and the problem was solved. Class diagram generate in a few seconds.
Before, I have version from September 2017.
