When I try to generate ORM code from an ERD using the wizard, VP hangs. There must be something in the ERD model as I can do it for a simple model but not for our larger (real) model.
Anyone else run into problems generating ORM code?
I’m also getting a Null Pointer Exception in the log file (see previous post) which is probably related. Just wondering if anyone else is actually using this feature.
After playing with this for a while, it SEEMS to have something to do with having not saved a change prior to code generation. I find that if I go to the diagram tree view, then File/Save DBVC Project, and THEN generate code, it never hangs.
On the other hand, if the Diagram Tree view shows an unsaved state (a ‘*’ next to the project name), the code generation often fails.
