hello everyone,
i used Visusal paradigm to reverse a python code, and i got a class digram without relationships. Even if i did try lot of times and configure the process well i still have the same result. Any idea how can i solve this prb ?
thank u
I share your experience. I couldn’t get associations either, even with both classes in the same file like this:
class A(object):
pass
class B(object):
def __init__(self):
self.a = A()
Note that if you use self.a_objects = []
in B
's constructor, the software can’t know that the list is supposed to take A
instances at a later point. That said, I think the code above contains all the necessary information.
Generally, if you don’t get a reply in the forum, you may want to send an inquiry to the support via their ticket system at http://www.visual-paradigm.com/support/ . I don’t know why, but they’re much more responsive to tickets than to forum posts. When I send them a ticket, it usually gets answered the same or next day, often already with a fix if there was a bug! Unfortunately, the support by Visual Paradigm in the forum might give the impression that they aren’t serious about customer support.
Stefan
sschwarzer - Thank you dude! I had the same problem like
Anonymous
