Hi Lilian,
Just a quickie - in a class mode that is being forward engineered to xsd schema…
If you go into the class properties and select the XML Schema tag and then choose Global Define = False it still generates the class at the root level of your schema.
My expectation would be that if the stereotype is XSDElement, if you choose Global Define =False then it should generate the class inline…
Can you ask your engineers to check for me please?
Many thanks!
Toby
