Hey guys,
I am currently struggling with an HTTP Request.
We’ve got a platform with all Objects either classes/tables etc. and I’m trying to receive those informations (which class/stereotype) so i can simply model them with my plugin instead of doing those manually.
However I’ve written an http request which does work in eclipse, but if i put it into my plugin it does not work.
to simplify i just tried to send a request to a website, than put the info into an array an print out just a single String but VP stops the moment the http request starts.
Any ideas what’s wrong?
I’m working with VP 10.2
my code
public class ClassGeneratorActionController implements VPActionController{
public void performAction(VPAction action) {
ViewManager viewManager = ApplicationManager.instance().getViewManager();
HTTP_Request almost = new HTTP_Request();
String[][] table = almost.sendRequest();
viewManager.showMessage(table[1][1]);
//HTTP_Request Class
import java.io.BufferedReader;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.URL;
import org.json.JSONArray;
import org.json.JSONObject;
public class HTTP_Request {
public String[][] content;
public String[][] sendRequest(){
try {
String url = "https://api.myjson.com/bins/1dvbb9"; //TABLE
URL obj = new URL(url);
HttpURLConnection con = (HttpURLConnection) obj.openConnection();
BufferedReader in = new BufferedReader(
new InputStreamReader(con.getInputStream()));
String inputLine;
StringBuffer response = new StringBuffer();
while ((inputLine = in.readLine()) != null) {
response.append(inputLine);
in.close();
JSONObject myresponse = new JSONObject(response.toString());
JSONObject d_object = new JSONObject(myresponse.getJSONObject("d").toString());
JSONArray results = new JSONArray(d_object.getJSONArray("results").toString());
content = new String[results.length()][2];
for(int i = 0; i<results.length();i++) {
JSONObject stereo = results.getJSONObject(i);
content[i][0] = stereo.getString("RET_VALUE");
content[i][1] = stereo.getString("RET_NAME");
} catch (Exception e) {
e.printStackTrace();
return content;
I’ve used the java-json.jar
Thank you
