Hi there!!
Please help me,i installed DB-VA SQl & it was installed successfully but now i tried to configure the DB as shown by the demo and when I test connection it give a “Connection Exception” with the following details.What should I do or missed out to do
java.lang.Exception: com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception:
** BEGIN NESTED EXCEPTION **
java.net.SocketException
MESSAGE: java.net.ConnectException: Connection refused: connect
STACKTRACE:
java.net.SocketException: java.net.ConnectException: Connection refused: connect
at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:156)
at com.mysql.jdbc.MysqlIO.(MysqlIO.java:283)
at com.mysql.jdbc.Connection.createNewIO(Connection.java:2541)
at com.mysql.jdbc.Connection.(Connection.java:1474)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:264)
at org.orm.ertodb.DriverWrapper.connect(DriverWrapper.java:27)
at java.sql.DriverManager.getConnection(Unknown Source)
at v.ifaa.i(:34)
at v.ifaa.f(:43)
at v.bsk.i(:633)
at v.dww.actionPerformed(:609)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at v.uyt.show(:427)
at v.ioba.a(:735)
at v.ioba.show(:745)
at v.wlf.i(:37)
at v.zog.actionPerformed(:247)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
** END NESTED EXCEPTION **
Last packet sent to the server was 0 ms ago.
v.bsk.i(:638)
v.uyt.show(:427)
v.ioba.a(:735)
v.ioba.show(:745)
v.wlf.i(:37)
