hi, im new vs paradgim and win8 64bit, first time i using win 7 32 bit and i have a project on it, then i using win8 64bit the project error can’t not connect with database( im using sqlite3). error show:
java.lang.Exception: An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
at System.Data.SQLite.UnsafeNativeMethods.sqlite3_open_v2(Byte[] utf8Filename, IntPtr& db, Int32 flags, IntPtr vfs)
at System.Data.SQLite.SQLite3.Open(String strFilename, SQLiteOpenFlagsEnum flags, Int32 maxPoolSize, Boolean usePool)
at System.Data.SQLite.SQLiteConnection.Open()
at NHibernate.Connection.DriverConnectionProvider.GetConnection()
at ORMTool.ORMTool.TestDotNetORMTool…ctor(String dialect, String connString, String driverClass)
log.no_ext
The version you using is pretty old and this problem possible to be fixed in the recent release. Would you mind send in your license key to support@visual-paradigm.com so that we can lookup your customer record and see is your license entitle for upgrade? Please include the URL of this forum post in your email. Thanks!
Rain Wong
