Hi ,
I have retrieved code and class diagram from a orcale9 db with JBuilder.
Code and diagram were created successfully.
If I wanna use the Fabrics now for reading or creating new objects I get the following errors:
23.08.2006 16:08:48 org.hibernate.cfg.Environment <clinit>
INFO: Hibernate 3.1.3
23.08.2006 16:08:49 org.hibernate.cfg.Environment <clinit>
INFO: loaded properties from resource hibernate.properties: {hibernate.cglib.use_reflection_optimizer=true, hibernate.cache.provider_class=org.hibernate.cache.HashtableCacheProvider, hibernate.max_fetch_depth=1, hibernate.jdbc.use_streams_for_binary=true, hibernate.format_sql=true, hibernate.query.substitutions=yes 'Y', no 'N', hibernate.proxool.pool_alias=pool1, hibernate.cache.region_prefix=hibernate.test, hibernate.jdbc.batch_versioned_data=true, hibernate.connection.pool_size=1}
INFO: using java.io streams to persist binary types
INFO: using CGLIB reflection optimizer
INFO: using JDK 1.4 java.sql.Timestamp handling
23.08.2006 16:08:49 org.hibernate.cfg.Configuration configure
INFO: configuring from resource: /ormmapping/Wilhemaomat.cfg.xml
23.08.2006 16:08:49 org.hibernate.cfg.Configuration getConfigurationInputStream
INFO: Configuration resource: /ormmapping/Wilhemaomat.cfg.xml
I didnt change anything about the code after creation. I just coded a test method to test the created code.
The ORM package is included well in the project.
Does anybody have a solution?
