How can I adress a specific Model Element or Diagram as Query-Parameter (Fill-In Doc)
Hi there,
when creating a Fill-In Doc I want to adress a specific DIAGRAM or ELEMENT of my model without having to select it later on in VP DocComposer.
Eg. I would like to place a statement like perhaps
${DIAGRAM, “Use Case Diagrams (Admin)”, “UseCaseDiagram”, Any=“MySpecificDiagramName”, PROPERTY=name}
into my Doc Base. As a result after importing my Doc Base into Doc. Composer I would not have to pick the specific diagram; instead Doc. Composer would find and select it automatically for me (without further interaction from me). Same idea applies to ELEMENTs…
Background is: If I need to change my Doc Base Word-Document I always have to re-pick my DIAGRAMs and ELEMENTs queried with “One” or “Any” by hand when I want to re-generate my project documentation.
How can I achieve this in VP?
Thanks for any input
Volker
in ${DIAGRAM, ...Any or One, ...}. you can specify:
PreferredDiagram.Name={diagram.name}
e.g.
${DIAGRAM, ..., Any, ..., PreferredDiagram.Name="My Diagram Name", ...}
in ${ELEMENT, ...Any or One or LoopInElement, ...}, you can specify:
PreferredElement.Name={element.name}
PreferredElement.UserId={element.userId}
in ${ELEMENT, ...LoopInDiagram, ...}, you can specify:
PreferredDiagram.Name=diagram.name with LoopInDiagram
Thanks a lot for the hint, looks pretty much like what I’m looking for. Is there a documentation available for additional parameters like those PreferredElement and maybe more? I was not able to find them in the Doc. Composer user guide.
Sorry, the document is not yet ready.
Let me try to show you here
${DIAGRAM, ...}
* format: ${DIAGRAM, name, "DiagramType(0..N)", NUMBER_OF_DIAGRAMS[One, Any, LoopInProject, LoopInElement], TEMPLATE[template_name, PROPERTY=property_name, ICON, IMAGE]}
* --- additional arguments ---
* SortBy=property_name(1..N)
* or
* SortBy=NoSort
* PreferredDiagram=Address of DiagramWithData(0..1)
* PreferredDiagram.Name=Name of DiagramUIModel(0..1)
* // the preferred diagram selected in this doc fields. If this doc field has no diagram selected, will find out this preferred-diagram, and assign into this doc field.
${ELEMENT, ...}
* format: ${ELEMENT, name, "ModelType(0..N)", NUMBER_OF_ELEMENTS[One, Any, LoopInProject, LoopInElement, LoopInDiagram], TEMPLATE[template_name, PROPERTY=property_name, ICON]}
* or
* SortBy=NoSort
* // used when NUMBER_OF_ELEMENTS = [LoopInDiagram]
* PreferredElement=element.address(0..1)
* PreferredElement.Name=element.name(0..1)
* PreferredElement.UserId=element.name(0..1)
* // the preferred element selected in this doc fields. If this doc field has no element selected, will find out this preferred-element, and assign into this doc field.
* // used when NUMBER_OF_ELEMENTS = [One | Any | LoopInElement]
* PreferredExcludedModelTypes=modelType(0..N)
* PreferredExcludedInstances=element.address(0..N)
${PROJECT, ...}
* format: ${PROJECT, TEMPLATE[template_name, PROPERTY=property_name]}
${TEXT}
* format: ${TEXT, NAME}
${PROPERTY, ...}
* format: ${PROPERTY, xxx}
${IMAGE}
* format: ${IMAGE}
${ICON}
* format: ${ICON}
${TEMPLATE}
* format: ${TEMPLATE, template-name}
PS: ${PROPERTY}, ${TEMPLATE}, ${IMAGE}, ${ICON} are used in a table,
which for-each a set of elements/diagrams and generate them into rows,
using the ${PROPERTY, …}, etc… to generate the current element/diagram’s property, template, icon, image.
