Is it possible to add “Note” object to cattegory Common, in that way this could be visible for other categories.
You may achieve this with following steps:
After that your selected note type will stacked under the note button. Press & hold the bottom right triangle of Note button will bring this up. You can also right click on diagram palette and select Expand Group to have it show in root level.
