Help!! i tried the usual way to change the Connecting lines style in visual paradigm Entity Relationships Diagram, which is right-click on the connector, choose formatting and styles, then format connector. the problem is when i applied the whole steps, nothing changed on my diagram workspace!! do you have any idea about how to fix this. I’m using a free trial.
Hi Omar,
Connectors in ERD should work the same as connectors in other diagrams, except that the relationship has an extra option for pointing its ends to associated columns:
And this article shows how you can change connector style of a connector:
Note that connector style can also be set diagram-based using diagram’s popup menu, from the “Connectors” sub-menu.
Hope this helps,
Antony.
