How to display unique index name?
I know it’s possible to display unique constraint name, but is it also possible to display unique index name?
Hi Jan,
Thank you for your post. Currently, we do not support displaying unique index name. Sorry about this.
Hopefully you will implement this easy feature.
I have asked this question because it could act as a workaround for the problem/limitation I experienced in Reverse engineer MySQL database with unique indices
Btw it would be even easier/nicer where you don’t have to display the index name (or constraint name) but just display an icon U1, U2 etc. for example:
column1 U1
column2 U2
column3 U2
where U1 is a unique constraint and U2 is a composite unique constraint. It’s just that you can see which columns belong to which unique constraint.
Thanks hopefully you can consider this feature.
Hi Jan,
I will pass your suggestion to our team, along with the other post you posted. Thank you for your valuable feedback.
