I use Visual Paradigm for UML for Vietnamese language. I use Unicode for encoding Vietnamese. When I export a report, VP don’t support for Unicode.
How to export a report with unicode encoding ??
Dear Dinh,
Our latest version of VP-UML (VP-UML 4.1) supports Vietnamese encoding in HTML documentation generation. You can download it at [url]http://www.visual-paradigm.com/download.php[url].
Rain
Hi Rain,
I also Vietnamese and try to down load VP-UML 4.1 and even update the latest hot fixed but can not generate Vietnamse report. We use UTF-8 encoding. Could you please review this feature soon.
Long
[quote=Rain]Dear Dinh,
Rain[/quote]
Dear Long,
Our engineers are now investigating your case. I’ll keep you informed on any news about this issue. If you have any further questions, please feel free to contact us again.
Rain
Hi Rain !
I’m beeing also faced by this problem.
Has unicode font been supported in Version 6.0 yet ?
Thanks,
Thank you so much, but in my case I’d like to generate into Word docs!?
I found that “Generate word report” dosen’t include Unicode option, so I have to generate pdf report, then convert pdf version to word version by another tool (ex. PDF Solid converter).
However, your tip is useful for me !
Hi quynm,
For Word report, Vietnamese should be supported by default. If you find your input text couldn’t display in the report, could you send me your project file for testing?
Please have a look the image and Attached project !
Expert-Phase 1.vpp
Thank you. Will test and get back to you.
Hi quynm,
The Vietnamese support for Word report is ready. Please download the patch at:
http://files3.visual-paradigm.com/200707/Patch/sp2_20070704x/VP_Suite_Windows_3_0_sp2_20070704x.exe
Please install it by overwriting the current installation. Feel free to let me know if there are any questions.
what a surprise !
Your engs solve the issue really quick !
I’ll try for a while.
Many thanks to you .
You are welcome!
By the way, I’d inform you that: Vietnamese isn’t also displayed correctly in VS editor after generating code.
I wonder whether if the new release fixed this issue or not ?
Cheers,
Hello quynm,
May I know whether you are generating code through ORM code generation or Instant Generator?
Yes, I generated by “Instant Generator” function !.
I’ll try after downloading…
cheers,
Hi quynm,
The fix we made for report generation wouldn’t fix the code generated by Instant Generator. We will check the problem first. Let’s keep in touch.
Hi quynm,
The fix is now ready. You can download the patch at:
http://files3.visual-paradigm.com/200707/Patch/sp2_20070712e/VP_Suite_Windows_3_0_sp2_20070712e.exe
thank you so much !
My pleasure!
