I am evaluating VP and I am trying to generate class diagrams for the existing classes I have. When I select on the existing java project or java classes under the project in eclipse, update UML Model and select UML Model are disabled.
How do I generate class diagrams for existing java classes in project?
I downloaded and installed professional Edition version 3.0.
i am new to this tool.
Can i generate class diagram with existing code(reverse engineering)
P.S.
VPUML Professional Edition has full support of code engineering (including reverse engineering).
But VPUML Standard Edition and evaulation of VPUML Professional Edition have limitation about it.
About SDE for Eclipse, Code engineering is only available in SDE for Eclipse Professioanl edition.
Real-Time Code Synchronization x x x
Java Code Generation # # x
Java Reverse Engineering % % x
Java Language Syntax Check % % x
(# and % meaining “available but with restrictions”)
Unquote. How come? Isn’t it rather ironic that people who simply need the code-to-UML feature out of this product just do not get it unless they pay for a PE? Come on…
