How to Generate ForEachSimpleRelationship each in a separate Row in a table
How can I get the values of ForEachSimpleRelationship iteration in a separate TableRow?
With the below code snippet, I get runtimeException viz:
"java.lang.RuntimeException: tableBlock> cannot contain the content (e.g ) without TableRow> & tableCell>"
Code Snippet:-
													<TableCell >
							                                         <Property property="name" fontSize="8" style="Normal"/>
							                                 </TableCell>
										               <TableCell>
													<ModelElementProperty property="from">
														    <Text>, </Text>
															</ModelElementProperty>
												   </TableCell>
							                     </TableRow>
											</ForEachSimpleRelationship>
										</HasRelationshipChecker>
Hi Shweta,
Thank you for your post. Do you mean you want to create one table per simple relationship? The code you included is incomplete. Would you mind re-including a more completed version of the XML?
Hi Jick,
I don’t want to create one table per relationship, instead want to have one row per relationship.
Here is the code which I am using.
template_xml_code.xml (3.4 KB)
The result with the above code is that, it groups all the relationship iteration for a ArchiMateCapability in one row. As shown below:
I want to have each relationship within a iteration for a ArchiMateCapability in separate row. Need As shown below:
Thanks in Advance
Shweta
Hi Shweta,
Thank you for your post. I have forwarded your question to our team for further studying. When there is any news, I will let you know.
Hi Shweta,
You may change the loop as example below to output one relationship per row.
       <IterationBlock allLevel="true" modelType="ArchiMateCapability">
		<HasRelationshipChecker modelType="ArchiMateUsedBy" direction="to">
			<ForEachSimpleRelationship type="ArchiMateUsedBy" ignoreLastSeparator="true">
				<TableRow>
					<TableCell>
						<ModelElementProperty property="to">
					</TableCell>
					<TableCell>
							<Text>, </Text>
					</TableCell>
				</TableRow>
		<HasRelationshipChecker modelType="ArchiMateUsedBy" direction="from">
				<TableRow>
					<TableCell>
					</TableCell>
					<TableCell>
							<Text>, </Text>
					</TableCell>
				</TableRow>
	</IterationBlock>
Hope this help!
Thanks Rain…
If I want to put a ParentModel of the ModelElementProperty in a separate Table cell, how that can be done?
Also is it posible to save the ParentModel’s value in a variable. That way when the model element block gets executed, I can then create a table cell & get the value from the parent model’s variable in a separate column.
Expected out put is as below:
