If I have 2 tables with an INTEGER(10) primary key, and create a many to many table in between, the resulting table also has an 2 INTEGER(10) fields.
The problem is that when I generate the DDL for SQLITE, the 2 tables ends up with INTEGER, while the inbetween table ends up with integer(10).
I figured out that I had to leave the ID Generator to Native in order to get INTEGER, but this field is not available on the inbetween table.
Hi Benoitd,
Thank you for your post. I have forwarded your case to our team for further studies. When there is any news I will post here.
Hi Benoitd,
According the our record the support of length was one of our user requests. It is optional. To remove (10), please set length to 0.
If I have 2 tables with an INTEGER ?
