I’m altering VP-UML to work on Smalltalk/squeak, and part of that involves getting rid of the ()'s and allowing a mthod to use : in its name so variabless can be listed.
Is there an easy way to just disable the ()'s, if not a java to squeak conversion?
I am sorry, but I do not understand your problem. Are you referring to messages in sequence diagram? By default, a message will not show (), only when you adjust the message type from Unspecified to Call, it shows (). Is this what you are looking for?
I am sorry, but I do not understand your problem. Are you referring to messaged in sequence diagram? By default, a message will not show (), only when you adjust the message type from Unspecified to Call, it shows (). Is this what you are looking for?
