Hi all,
Please can any1 help me out in representing the threads in Sequence diagram
Hi Akshay Rao KV,
Thanks for your post. You can create an active object, then create a lifeline with the active class as Base Classifier. After that, create a asynchronous message to the lifeline (just right-click on the message and turn on “Asynchronous” in the popup menu).
You can refer to the attached image. Hope this helps.
Is there another way to represent threads via a different diagram? Visually, this approach doesn’t look any different than two (non-threaded) lifelines. I use the create message for threads, but don’t know if that’s the right approach.
Hi David Matsumoto,
Thanks for your post. Yes, create message is the correct approach.
