I hve tried to limit the returned results in ORM but unsuccessfully(= select top), I can only use Procedure to resolve this problem but this is not good because i must regenarate ORM layer each time i have a new Procedure. Can anyone give me a solution? thank you very much. :roll:
Hello ichbinvinh,
You may try using Criteria. Please call: criteria.setMaxResults()
hello Jick,
i use ORM.net of olero not nHibernate for ASP.NET 2.0. I must do that
DataManager dm = new DataManager(Config.Dsn);
DataSet ds = dm.FillDataSet("SELECT TOP 5 * FROM Article ORDER BY Hits DESC", true);
// merge the data into DataManager
dm.PopulateObjectsFromDataSet(ds, "Article");
ArticleCollection ac = dm.GetArticleCollectionFromDataSet().FilterByLangCode(BasePage.CurrentLanguage);
DataList.DataSource = ac;
DataList.DataBind();
thanks for reply me
If ORM could generate hbm with ‘formula’ as property element in property tag it might not need criteria.setMaxResults()
