Hi… I have created a class File which has an operation named load().
In VP, I want to specify that the load operation is asynchronous. I also want to define the return type as a Javascript Promise which resolves with the type text.
Basically, I want to document this Javascript class in Visual Paradigm:
We do not support generating JavaScript, so I suppose you are asking for the way to model async method in UML. As we know, UML does not specify how to represent async method. If you want to draw a diagram for documentation purposes, I suggest you specify the return type of your method as : “Promise”
