Hi, I need to instantiate the decision table that I have active in the project in an object of class IDTBDecisionTable. The only thing I was able to do was this:
But I still haven’t figured out the difference between an object of class IDTBDecisionTableEditorDiagramUIModel and one of IDTBDecisionTable. How can I instantiate the table I have in the project in an IDTBDecisionTable object? I need it to extract internal values and do checks to optimize the table itself.
Hi Jick,
I need the data inside the decision table, i.e. the values of the action, of the conditions and of the rules to check for probable anomalies and if they are found then correct them.
So I think I should instantiate an object of class IDTBDecisionTable and then extract the data I need.
I don’t know if I expressed that the right way.
Hi Jick,
I’m so sorry, but I’ve tried and still don’t understand which classes and methods I need to use to set the reference to the IDTBDecisionTable so that I can access the data. Can I ask you for a code example please?
