Dear sir or madame,
i used DB Visual Architect for one of my projects to genrate the OR-Mapping from my ERD. I choosed my primary key in a column which data type is uniqueidentifier and an ID generator of guid.
But in the generated NHibernate mapping file the definition of the type is string:
and the property in the associated class is also string.
By debugging the code i recieve a System.ArgumentException: identifier type mismatch Parametername: id.
Then i changed manually the type in the mapping file to “type=System.Guid” and the propertys in the class also to Guid!
Now it works! Is it a bug in your system or is it my failure?
Thank you for your answer!
