I have downloaded the non installable VP UML plugin for Netbeans 6.5. Can u somebody help me to import that plugin ijnto Netbeans?
Hi user,
Thanks for your post. In order to integrate VP-UML with NetBeans, you need to installed Professional Edition or Enterprise Edition of VP-UML. Then you need to start VP-UML and select Tools > IDE Integration to run installation.
More details of integration with NetBeans in VP-UML can be found from the following link:
http://content.europe.visual-paradigm.com/media/documents/vpuml52iug/html/IDEIntegrationUserGuide-DHTMLHelp-3-1.html
Hope this helps. If there is any further inquiry, please feel free to ask.
BTW, SDE for NetBeans and DB-VA for NetBeans also support integration with NetBeans, but they are embedded inside the NetBeans so everything is done inside NetBeans (VP-UML and NetBeans are run in separate frames but still they can communicate with each other for cod synchronization).
