I attached a sample XMI file (two classes, “$ phpuml Domain/Factory/ -o /var/tmp/”). I there something wrong with the XMI or does VP-UML only accept XMI from pre-defined exporters?
Thanks for your message and I’ve forwarded the details to our engineers to follow-up. I’ll get back to you once there are any feedback. Feel free to contact me if you need any help.
I would like to let you know the fail to import XMI problem has been fixed and please run the VP Suite Update to update the software to latest patch (sp1_20110709e or later). Details about update to latest patch can be found at
thank you very much for the patch, the initial import is working now. What I am trying to achieve is the following:
import XMI => I have classes in VP
create a class model diagram (with color coding maybe)
update the code in my IDE
create a new XMI-export
import that XMI in my VP-project => model elements get merged with elements from XMI
Currenty I get the error “Unknown exporter PEAR\PHP_UML” when I try to merge the new XMI into my VP-project. Is that event possible?
I guess that is what the Standard Edition is good for. “Instant reverse engineering” works as expected on initial import, but when I try to update my model from modified source code, my layout modifications on the model get lost (tested with background color). Is there a way to preserve presentation attributes on my model?
