I am getting a Import Failed message while importing a Rose project. This is the exact message:
Start parsing the mdl file…
Import failed:
Could not resolve variable $JCAF_ROOT
Please define JCAF_ROOT in property file C:\Dev\segments\JCAF\JCAFCore\modelJCAFCore.properties
I use virtual pathes in the Rose model set up through the Virtual Path Map. What is this property file and how can I define the path variable in it?
I am using VP UML EE (evaluation copy) Ver5.5 (Build sp1_20060408)
Thank you for your post. Since we are unable to resolve JCAF_ROOT by just reading the mdl file, so you require to provide the mapping of this variable.
Please follow the steps below to solve the problem:
Create the property file C:\Dev\segments\JCAF\JCAFCore\model\JCAFCore.properties
Define the JCAF_ROOT property by adding the following line inside the property file
JCAF_ROOT=c:\path\
(where c:\path\ is the path for JCAF_ROOT)
