How can you import the existing jar files to the project in order to access the java libraries and import in your classes??
I tried importing the jar files but it is not accepting to add the jar file to the list. I am using Visual Paradigm UML Professional Edition.
Thanks in advance.
SID
Hi SID,
Thanks for your post. You can use the Instant Reverse feature for importing the jar files. Please select Tools > Instant Reverse > Java…, then you will be able to specify the jar file to be imported.
You may refer to the link below for more details of Instant Reverse for Java:
http://oldresources.visual-paradigm.com/tips_and_tricks/code_engineering/reverse_engineering_using_instant_reverse.html
If there are any further inquiries, please do not hesitate to contact me again.
