Hi!
I have some problems until i install VP Suite 2.3.
First the Setup says, the last Setup wasn’t successful and the Java VM might be corrupt. After that it says, it couldn’t find the Java VM and let me choose it. If i choose the newest Java.exe (V5.0), the Setup will break with an error-message. This is the content of the logfile:
Exception:
java.lang.UnsatisfiedLinkError: Can’t load library: C:\Dokumente und Einstellungen\xxx\Lokale Einstellungen\Temp\e4jA5.tmp_dir12095\i4jinst.dll
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at com.install4j.runtime.installer.platform.win32.Common.init(Unknown Source)
at com.install4j.runtime.installer.platform.win32.WinDel.prepareDeletion(Unknown Source)
at com.install4j.runtime.installer.platform.win32.WinDel.scheduleRecursive(Unknown Source)
at com.install4j.runtime.installer.Installer.main(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
System properties:
java.runtime.name=Java™ 2 Runtime Environment, Standard Edition
exe4j.moduleName=c:\dokume~1\xxx~1\desktop\vp_sui~1.exe
exe4j.semaphoreName=c:_dokume~1_xxx~1_desktop_vp_sui~1.exe
sun.boot.library.path=c:\programme\java\jre1.5.0_10\bin
java.vm.version=1.5.0_10-b03
java.vm.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
path.separator=;
java.vm.name=Java HotSpot™ Client VM
file.encoding.pkg=sun.io
user.country=DE
sun.os.patch.level=Service Pack 2
java.vm.specification.name=Java Virtual Machine Specification
user.dir=C:\DOKUME~1\XXX~1\LOKALE~1\Temp\e4jA5.tmp_dir12095
java.runtime.version=1.5.0_10-b03
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.endorsed.dirs=c:\programme\java\jre1.5.0_10\lib\endorsed
os.arch=x86
java.io.tmpdir=C:\DOKUME~1\XXX~1\LOKALE~1\Temp
line.separator=
java.vm.specification.vendor=Sun Microsystems Inc.
user.variant=
exe4j.tempDir=C:\DOKUME~1\XXX~1\LOKALE~1\Temp\e4jA5.tmp_dir12095
os.name=Windows XP
sun.java2d.noddraw=true
sun.jnu.encoding=Cp1252
java.library.path=C:\Dokumente und Einstellungen\xxx\Desktop;.;C:\WINDOWS\system32;C:\WINDOWS;C:\Programme\Oracle;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programme\Microsoft Visual Studio\Common\Tools\WinNT;C:\Programme\Microsoft Visual Studio\Common\MSDev98\Bin;C:\Programme\Microsoft Visual Studio\Common\Tools;C:\Programme\Microsoft Visual Studio\VC98\bin
java.specification.name=Java Platform API Specification
java.class.version=49.0
sun.management.compiler=HotSpot Client Compiler
exe4j.isInstall4j=true
os.version=5.1
user.home=C:\Dokumente und Einstellungen\xxx
user.timezone=
java.awt.printerjob=sun.awt.windows.WPrinterJob
file.encoding=Cp1252
java.specification.version=1.5
java.class.path=C:\DOKUME~1\XXX~1\LOKALE~1\Temp\e4jA5.tmp_dir12095\i4jruntime.jar;C:\DOKUME~1\XXX~1\LOKALE~1\Temp\e4jA5.tmp_dir12095\user.jar;C:\DOKUME~1\XXX~1\LOKALE~1\Temp\e4jA5.tmp_dir12095\content.zip;
user.name=Xxx
java.vm.specification.version=1.0
java.home=c:\programme\java\jre1.5.0_10
sun.arch.data.model=32
exe4j.launchName=C:\Dokumente und Einstellungen\xxx\Desktop\VP_Suite_Windows_2_3_20060625.exe
user.language=de
java.specification.vendor=Sun Microsystems Inc.
awt.toolkit=sun.awt.windows.WToolkit
java.vm.info=mixed mode, sharing
java.version=1.5.0_10
java.ext.dirs=c:\programme\java\jre1.5.0_10\lib\ext
sun.boot.class.path=c:\programme\java\jre1.5.0_10\lib\rt.jar;c:\programme\java\jre1.5.0_10\lib\i18n.jar;c:\programme\java\jre1.5.0_10\lib\sunrsasign.jar;c:\programme\java\jre1.5.0_10\lib\jsse.jar;c:\programme\java\jre1.5.0_10\lib\jce.jar;c:\programme\java\jre1.5.0_10\lib\charsets.jar;c:\programme\java\jre1.5.0_10\classes
java.vendor=Sun Microsystems Inc.
file.separator=
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
sun.io.unicode.encoding=UnicodeLittle
sun.cpu.endian=little
sun.desktop=windows
sun.cpu.isalist=
This happens when i use an older Java Version too. The newest Version of VP (Version 3) i can’t use, cause there is no license for it (i tried at all).
Could you please help me to fix the problem?
Thanks in advance.
BTW: The VP Version 3 can be installed without problems.
