Can anybody please help with installation issues of VP-UML ???
The downloaded file is vpumlce_20030401.exe and whenever I try to run it it is coming to the message asking to change a location for extracting the installer.
Dear Nick,
The problem is your temp directory has not enough space. Please select a drive which has about 400MB. May be you can download the no install version. With the no install version you only need to unzip it. I think it should solve your problem.
I downloaded the no install version and I tried to run it on Windows 98 and RedHat 8 using the JRE 1.4.1.
Whenever I try to run the linux script using sh or if I execute the .exe file on Windows or if I just try to run it typing “java -jar vpuml.jar”, the response is the same:
C:\vpuml>jre\bin\java -jar vpuml.jar
java.lang.NoClassDefFoundError: com/jidesoft/docking/DefaultDockableHolder
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:502)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:1
3)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:250)
at java.net.URLClassLoader.access$100(URLClassLoader.java:54)
at java.net.URLClassLoader$1.run(URLClassLoader.java:193)
at java.net.URLClassLoader.findClass(URLClassLoader.java:186)
at java.lang.ClassLoader.loadClass(ClassLoader.java:299)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:265)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315)
at C6958.run(C6958)
at java.lang.Thread.run(Thread.java:536)
I tried to download the PE trial version but I am getting a pop-up message that says ‘the magic numbers did not match. Download another copy’. I tried dowloading from other sites for about 3-4 times already I still get the same message. Can somebody help? Thanks.
