I am trying to install the VP Suite on ubuntu and get the error below. I have downloaded it twice with the same result so it is unlikely to be a corrupt download. This is a little disappointing as the product looked very slick when I downloaded and trialled the windoze version.
gregh@seventeen:/opt/vp_suite$ sudo ./VP_Suite_Linux_3_4_sp2_20090212.sh
Unpacking JRE ...
Preparing JRE ...
./VP_Suite_Linux_3_4_sp2_20090212.sh: 229: bin/unpack200: not found
Error unpacking jar files. Aborting.
You might need administrative priviledges for this operation.
gregh@seventeen:/opt/vp_suite$ ls -l
total 136828
-rwxr-xr-x 1 gregh users 139966946 2009-03-10 18:11 VP_Suite_Linux_3_4_sp2_20090212.sh
gregh@seventeen:/opt/vp_suite$ uname -a
Linux seventeen 2.6.27-11-generic #1 SMP Thu Jan 29 19:28:32 UTC 2009 x86_64 GNU/Linux
But when I want to install the program under Ubuntu 8.1 it stops with an error message.
It open a setup window but it is empty. Only the headline is shown " Setup - VP Suite 3.4.
Some times when we install some applications in Ubuntu , the menus are not displayed properly. On searching I found out that this does not happen when you using Java 6 , Since I need to keep Java 5 for my other applications I disabled the visual settings and it worked for me System => Preference => Appearance => Visual Effects => NONE
It worked for me
[quote=Anonymous]I did downloaded the Visual-Paradigm file from the following Server.
[quote=Anonymous]Some times when we install some applications in Ubuntu , the menus are not displayed properly. On searching I found out that this does not happen when you using Java 6 , Since I need to keep Java 5 for my other applications I disabled the visual settings and it worked for me System => Preference => Appearance => Visual Effects => NONE
It worked for me
daniil@book:/tmp/VP_Suite5.0/bin$ sudo ./VP_Suite
[sudo] password for daniil:
Preparing JRE ...
./VP_Suite: 195: bin/unpack200: not found
Appearance > Visual Effects is set to “none”.
Ubuntu is 10.04.1 AMD64
libxp-1.0.0-3
$uname -a
Linux myhost 2.6.36-ARCH ...
export AWT_TOOLKIT=MToolkit
I have the save issue
[root@myhost opt]# ./VP_Suite_Linux_5_0_sp1_20101119.sh
Unpacking JRE ...
Preparing JRE ...
./VP_Suite_Linux_5_0_sp1_20101119.sh: line 256: bin/unpack200: No such file or directory
