Hi
I just downloaded the Community Edidtion of Visual Paradigm. When installing I always get the following:
Could not install file
c:\Program Files\VP Suite 2.0\Samples\Textual Analysis\images\1.png
This is then followed with:
Exception:
java.util.zip.ZipException: invalid entry size (expected 80514 but got 80515 bytes)
at java.util.zip.ZipInputStream.readEnd(Unknown Source)
at java.util.zip.ZipInputStream.read(Unknown Source)
at java.util.zip.ZipInputStream.closeEntry(Unknown Source)
at java.util.zip.ZipInputStream.getNextEntry(Unknown Source)
at com.install4j.runtime.installer.Installer.installContent(Unknown Source)
at com.install4j.runtime.installer.Installer.doStandardInstallation(Unknown Source)
at com.install4j.runtime.installer.Installer.doInstallation(Unknown Source)
at com.install4j.runtime.installer.Installer.install(Unknown Source)
at com.install4j.runtime.installer.frontend.screens.InstallationScreen$1.run(Unknown
Source)
System properties:
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
exe4j.moduleName=h:\downlo~1\vp_sui~1.exe
exe4j.processCommFile=C:\DOCUME~1\Hassan\LOCALS~1\Temp\e4j_p300.tmp
exe4j.semaphoreName=h:_downlo~1_vp_sui~1.exe
sun.boot.library.path=c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\bin
java.vm.version=1.5.0_04-b05
java.vm.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
proxyUser=
path.separator=;
java.vm.name=Java HotSpot(TM) Client VM
file.encoding.pkg=sun.io
user.country=US
sun.os.patch.level=Service Pack 4
java.vm.specification.name=Java Virtual Machine Specification
user.dir=C:\DOCUME~1\Hassan\LOCALS~1\Temp\e4j4.tmp_dir25071
java.runtime.version=1.5.0_04-b05
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.endorsed.dirs=c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\lib\endorsed
os.arch=x86
proxyPort=
java.io.tmpdir=C:\DOCUME~1\Hassan\LOCALS~1\Temp\
line.separator=
java.vm.specification.vendor=Sun Microsystems Inc.
user.variant=
exe4j.tempDir=C:\DOCUME~1\Hassan\LOCALS~1\Temp\e4j4.tmp_dir25071
os.name=Windows 2000
proxySet=false
sun.java2d.noddraw=true
sun.jnu.encoding=Cp1256
java.library.path=H:\Downloads;.;C:\WINNT\system32;C:\WINNT;C:\PVSW\BIN;C:\WINNT\system32;C:
\WINNT;C:\WINNT\System32\Wbem;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;C:\Program Files\Common Files\Roxio Shared\DLLShared
java.specification.name=Java Platform API Specification
java.class.version=49.0
sun.management.compiler=HotSpot Client Compiler
exe4j.isInstall4j=true
swing.disableFileChooserSpeedFix=true
os.version=5.0
user.home=C:\Documents and Settings\Hassan
user.timezone=GMT+04:00
java.awt.printerjob=sun.awt.windows.WPrinterJob
file.encoding=Cp1252
java.specification.version=1.5
java.class.path=;C:\DOCUME~1\Hassan\LOCALS~1\Temp\e4j4.tmp_dir25071\i4jruntime.jar;C:\DOCUME
~1\Hassan\LOCALS~1\Temp\e4j4.tmp_dir25071\user.jar;C:\DOCUME~1\Hassan\LOCALS~1\Temp\e4j4.tmp
_dir25071\platform.zip;C:\DOCUME~1\Hassan\LOCALS~1\Temp\e4j4.tmp_dir25071\content.zip;
user.name=Hassan
proxyHost=
java.vm.specification.version=1.0
java.home=c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre
sun.arch.data.model=32
exe4j.launchName=H:\Downloads\VP_Suite_Windows_2_0_20050624.exe
user.language=en
java.specification.vendor=Sun Microsystems Inc.
awt.toolkit=sun.awt.windows.WToolkit
java.vm.info=mixed mode
java.version=1.5.0_04
java.ext.dirs=c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\lib\ext
sun.boot.class.path=c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\lib\rt.jar;c:\doc
ume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\lib\i18n.jar;c:\docume~1\hassan\locals~1\te
mp\e4j4.tmp_dir25071\jre\lib\sunrsasign.jar;c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir250
71\jre\lib\jsse.jar;c:\docume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\lib\jce.jar;c:\do
cume~1\hassan\locals~1\temp\e4j4.tmp_dir25071\jre\lib\charsets.jar;c:\docume~1\hassan\locals
~1\temp\e4j4.tmp_dir25071\jre\classes
java.vendor=Sun Microsystems Inc.
file.separator=\
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
sun.io.unicode.encoding=UnicodeLittle
sun.cpu.endian=little
sun.desktop=windows
proxyPassword=
sun.cpu.isalist=
Anyone have any suggestions?
