Installing netBeans SDE CE on Mac OS X
Encountering two problems with the installer (sdecejb_20040224.jar):
  1. When trying to choose the installation directory by clicking on the Choose button, the installer goes away, never to come back, and I have to quit from the installer menu. If I choose to continue with the default location, I can go on, but …
  2. The Installer asks for my netBeans installation directory, which (for Mac OS X) is somewhere inside …/NetBeansLauncher/Contents/… But whre exactly? (Remember that NetBeansLauncher is a package (is this the right term :), and its contents actually reside in a Contents directory inside the application file NetBeansLauncher).
Had the same problem with the SDE for JBuilder. Then I gave up, but this time I won’t. Help!
TIA,
Gidi
I have exactly the same problem (using Powerbook G4 running OS X 10.3.3). Help would be greatly appreciated.
Using the native Mac file chooser would allow navigation into the package (I think).
I have solved the problem. Use the no_installer_XXXX.zip and follow the instructions in Appendix A of the user guide.
I have SDE installed and running perfectly (NetBeans 3.6/Java1.4.2/OS X 10.3)
Yup, the no_installer works. Thanks.
There is now a Mac OS X version, but it fails in exactly the same way…
Gidi
