I just downloaded the latest CE version and installed on Win2k professional. After installation everything looks OK, and the user interface was launched, I even saved my class diagram.
The problem is after I exit the program, I don’t know how to start it again. There is nothing in the short-cut folder, all jar and exe files do not work in the Program Files folder. I checked the installation log and find the following errors.
Any ideas? Thanks!
Yi
The follosing is the installation log
Summary
Installation: Successful with errors.
10 SUCCESSES
0 WARNINGS
7 NONFATAL ERRORS
0 FATAL ERRORS
Action Notes:
None.
Install Log Detail:
Install Directory: C:\Program Files\Visual Paradigm for UML Community Edition
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Install Directory: C:\Program Files\Visual Paradigm for UML Community Edition\UninstallerData
Status: SUCCESSFUL
Install Uninstaller: Visual Paradigm for UML Community Edition (Install All Uninstaller Components)
Status: SUCCESSFUL
Status: SUCCESSFUL
Install Directory: C:\Program Files\Visual Paradigm for UML Community Edition\UninstallerData\resource
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\UninstallerData\resource\iawin32.dll
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\UninstallerData\resource\remove.exe
Status: SUCCESSFUL
Make Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Visual Paradigm for UML Community Edition, Value Name: DisplayName, Value Data: Visual Paradigm for UML Community Edition
Status: SUCCESSFUL
Make Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Visual Paradigm for UML Community Edition, Value Name: UninstallString, Value Data: "C:\Program Files\Visual Paradigm for UML Community Edition\UninstallerData\Uninstall vpumlce.exe"
Status: SUCCESSFUL
Create LaunchAnywhere: Visual Paradigm for UML Community Edition.exe (Install All LaunchAnywhere Java Executable Components)
Status: SUCCESSFUL
Status: ERROR
Additional Notes: WARNING - Platform Not Supported for Pure Java installer: LaunchAnywhere executables not installed
ERROR - Error writing LaunchAnywhere components (Access Denied)
Create LaunchAnywhere: Visual Paradigm Learning Center.exe (Install All LaunchAnywhere Java Executable Components)
Status: SUCCESSFUL
Status: ERROR
Create LaunchAnywhere: Visual Paradigm for UML Update.exe (Install All LaunchAnywhere Java Executable Components)
Status: SUCCESSFUL
Status: ERROR
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpuml.jar
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpupdate.jar
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpumlresources.jar
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\PostInstall.zip
Status: SUCCESSFUL
Registry Entries:
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpumlupdate.ico
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpumlproject.ico
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpuml_notation_guide.pdf
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\vpuml_userguide.pdf
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\Visual Paradigm Learning Center.ico
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\product.info
Status: SUCCESSFUL
Custom Action: installersupport.DefaultFolderCreater
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\Tutorial.html
Status: SUCCESSFUL
Install File: C:\Program Files\Visual Paradigm for UML Community Edition\index.html
Status: SUCCESSFUL
Status: SUCCESSFUL
Create Shortcut: C:\Program Files\Visual Paradigm for UML Community Edition\index.html.lnk
Status: ERROR
Additional Notes: ERROR - Error while trying to create shortcut
Create Shortcut: C:\Program Files\Visual Paradigm for UML Community Edition\Tutorial.html.lnk
Status: ERROR
Create Shortcut: C:\Program Files\Visual Paradigm for UML Community Edition\vpuml_userguide.pdf.lnk
Status: ERROR
Create Shortcut: C:\Program Files\Visual Paradigm for UML Community Edition\vpuml_notation_guide.pdf.lnk
Status: ERROR
Custom Action: installersupport.PostInstallAction
Status: SUCCESSFUL
Custom Action: installersupport.PreLauncher
Status: SUCCESSFUL
