Would like to be able to generate model code for a language not listed.
Appears the limitation would be the default template to start with and the setting the filename. Maybe the instant generator could provide the default vm template to start with. Java language defaults to JavaClass.vm I think so being able to declare the root velocity template could solve the issue.
I’m unsure where to plugin the filename. Currently I’m generating as Java with a customized template and then changing the extension on all the .java classes.
