If Show As Containment relationships is selected, the class diagram is drawn neatly. If I unselect it, the classes are all on top of each other at the upper left corner of the class diagram
The libraries have include and src folders inside them. The following scenarios trigger this for me
selecting Library2 only
selecting source (small letters) and Library1
I have a feeling that it is breaking due to heavy use C++ templates and variable arguments on the class template parameters but it would be best if I can send a log to you as the log window is not showing any errors, only that I have the latest VPP version.
Thanks for pointing out auto layout as it is my first time using it and it works. So it is turning out to be a not so critical issue but a bug as auto layout works but not importing by default.
I would like to let you know the unable to reverse source code problem has been fixed. Please update the software to latest patch build (20200630aa or later) to get the problem fixed. Details about update to latest patch can be found at
