i’ve made Instant Reverse of some c++ .h files in a project.
The classes are fine but i miss the associations…
Are there some ways to fix this?
Regards Matte
Regards Matte
Hello Matte,
May I know which OS are you running? Also, could you send me your .h file for reproducing the problem? Please send to:
jick@visual-paradigm.com
when using instant reverse with some c++ source which makes use of the doxgen @file Attribute I get several errors:
Reason :
Error in parsing source file.
xxx.h:6: Warning: the name `xxx.h’ supplied as the second argument in the \file statement is not an input file
C code in line 5-7:
Hi feese,
I have forwarded your case to our developers. Once there are any news, I will let you know.
Hi feese,
Unfortunately, we were unable to reproduce the problem you have. First, may I have your source files? Second, may I have your log file ($vp-suite-install-dir/bin/vp.log)? Finally, may I know which OS are you running in?
Hello Jick!
I made reverse c++ on Windows platform - all ok,
but in linux - generalization don’t create. What is it?
P.S.
How can I change params forward generation: I want to place classes in one file?
P.P.S.
Sorry for my english :?
Hi Jick,
I’ve found the problem. The path at the doxygen @file tag wasn’t right. I wonder if there is a way to prevent vp to parse the code comments?
Cheers
Hello avp,
Could you send me the source?
Hello, Jick!
Code is simple
class M1 : public QThread, public QObject
class M2 : public M1
In Linux version of VP generalization don’t work, but in Windows version is all ok
Hello feese,
Regarding the @file issue, could you send me a sample file? We do not quite get and could not reproduce the problem.
