I was trying to use Instant Reverse with my .NET Code.
It works fine with some projects, but sometimes I get a message like "The dll/exe is not a .NEt compatible ".
I’ve searched in the forum trying to find out what’s wrong, and I read about copying all the references used in the project to the same directory (setting their “Copy Local” property") to true. So, Instant Reverse works sometimes, but I have a class library (dll project) created in Visual Studio in C# and the I.Reverse does not work.
Thank you for your post. Would it be possible for you to send me your DLL for checking so that we could tell you the reason why it does not work? Thank you.
Also it would be great if you could send me the log file for checking. You can find the log file at %VP Suite installation dir%/bin.
The problem is caused by failed to reference the assembly “Microsoft.WindowsCE.Forms”. Please try including this assembly for reversing, the problem should then be solved. An alternative solution, of course, is to remove the device specific stuff in the dll.
