Hello - I’ve got VP Enterprise Trial version on my MacOS and am trying to reverse engineer a C# codebase. I tried using Instant Reverse, but get this error:
Reason :
Output file from parsing source code does not exist.
/Users/carlos/Library/Application Support/VisualParadigm/tmp/irTemp15347595723358925154temp/ouf/index.xml
If the above file does not exist, please make sure there are execute permission to all files under the following directory:
/Applications/Visual Paradigm.app/Contents/Resources/app/bin/vp_windows
May I know is the file mentioned in message “/Users/carlos/Library/Application Support/VisualParadigm/tmp/irTemp15347595723358925154temp/ouf/index.xml” exist in your system? If yes then would you please it to us for checking? You can send the file to support@visual-paradigm.com if you don’t want to post it to our forum. Look forward to hearing from you.
Would you please zip up the /Users/carlos/Library/Application Support/VisualParadigm/tmp/irTemp15347595723358925154temp folder and send us for checking? You can send it to support@visual-paradigm.com in case you don’t want to upload it to forum. Look forward to hearing from you.
