Is there a known problem exporting a model with Interfaces to XMI 1.2?
I just tried it and all my interfaces became regular classes. I want to use v1.2 to integrate with another tool that exports PHP code. I haven’t tried the other two XMI versions.
I’m attaching a test project and the exported XMI for you to look at.
Sorry to ask so many questions, VP-UML seems like it could be a really really amazing program, so I’m trying it out as best I can.
Don’t say so. We are happy to see your post with suggestions and problem report.
I just tried your XMI by reversing it back into VP-UML, the IThing interface can be reversed without problem. I also tried exporting XMI from your .vpp file, and importing it back. The result is fine as well. May I know why you said that the interfaces became regular classes? My judgment is based on the existence of <> stereotype. How about you?
I’m under the impression that the UML:Interface tag should be used for Interfaces rather than the UML:Class tag. I don’t think other programs use the stereotype tag to determine whether an element is an interface or class - I think they use the UML:Interface tag. So, where VP-UML can import the XMI file and understand it, my other programs think the interface is a regular class.
– Actually, looking a little more, there is still a big problem.
The interface is recognized as an interface, however the class that implements the interface is not marked as implementing the interface.
I don’t know exactly what the XMI should look like, because I don’t really know XMI, I just try to use it. So I have attached a simple XMI file made with ArgoUML that works with my other program. VP-UML seems to import this file fine. Maybe it will help you? argoTest.xmi
We also use UML:Abstract to represent the Realization, but the supplier/client are different. We exported as @supplier, but your XMI was exported with node UML:Dependency.supplier. May be both are correct. But we found that most of the tools handle this as @supplier, so we adopted this approach.
This is a note to inform you that a newer release is out. Since you were asked by me to use a patch, I would suggest you run the product updater to advance to the latest release. Feel free to let me know if there are any questions.
