I get an Invalid configuration of SDE for Ecplise/IBM Webshpere
Invalid home Ecplise/IBM Webshpere home directory.
What can I do to fix this.
Excplise was installed, but not in c:\ecplise
thanks
thanks
Dear Tim,
Did you select the correct Eclipse home directory? It should be the directory where eclipse.exe is located.
Regards,
Antony.
What do you mean, selct the correct eclipse home directory …
Do you mean that where I install the software should be the same directory as eclipse.exe lis installed?
I did not see any other place that you choose this.
Tim
Tim,
The installer will ask you where Eclipse is installed, so it can install the SDE plugins into Eclipse.
The eclipse home is where the eclipse.exe is found. So choose that directory when it asks for your Eclipse/IBM Websphere directory.
Hope this helps
Martyn
I am trying to install VP_Suite_Windows_1_1_20050222.exe. It never asks where eclipse is installed. Of course, I may not be installing the right thing either.
Tim
Tim,
Does it ask for other IDE’s such as JBuilder, Visual Studio or IntelliJ?
Martyn
No it does not.
It has a window which asks what do you what to install.
The sequence is in the attached file.
Hi Tim,
I think you have an old version which has an old installer. Could you try downloading the latest version?
Thanks.
Martyn
In the Select Visual Paradigm Product , The only selection is SDE for Eclipse/IBM Websphere Stdio, which is checked. The next window, Product configuration, I selected the community edition, The Install in existing Eclipse/IBM Websphere Studio is selected. Selecting Next causes the error.
A popup or dialog never appears asking where Ecplise is installed.
Of course, I installed eclipse in a non-standard place, but have tried on another machine and get the same error.
I have no idea what happened to the attachment in my previous post.
I’ll give it a shot.
I’ll get back to you with results.
Using VP Suite build 20050222 I get the same error.
The Product configuration window shows he SDE for Ecplispe …, it is selected,
The Install in existing Ecplise/… selection is selected, however, an Invalid Directory ? shows to the right of this. There appears to be nothing to change this to make it right.
Dear Tim,
Have you typed the correct Eclipse home directory near the “Install in existing Ecplise” field? You need to specify it because our installer will not detect this automatically. If the typed Eclipse home directory is invalid then the “Invalid Directory ?” error will disappear.
Regards,
Antony.
Anthony,
That was the trick.
I suggest that the text field for this be near that Install in exisintg radio button. It is not obvious that the text field is for that purpose but for the choice below.
Dear Tim
I agree that this would be quite confusing for users, we will try to add more description to the input fields that are not obvious for their purposes. Thank you very much for your suggestion.
Regards,
Antony.
i can not understand how i have to install .
DB visul Architect 1.0
Click only on CBVA for NetBean/Sun ONE(DBVA-NB)
I clik only in this one.IT IS RIGHT???
next
Configuration
Visual Paradigm for UML 4.1
edition??? Which one do i have to choice???
i try the Comunity(before i tryed the enterprise)
Then
SDE for NetBean/Sun one 2.1
Clik on Install in existing NetBean/sun ONE
Directory C:\ProgramFile|javaSun
then DBVA for NetBean/sun one 1.0
clik on Install in existin NetBean/Sun ONE
directory C:\Program File|javaSun
then
Press next
i have the errors ???
"invalid configuration of SDE for NetBean/Sun One:
Invalid NetBean/Sun ONE home directory
Dear luca,
Are you sure the directory you typed “C:\Program File|javaSun” is the directory where you have an installed NetBeans/Sun ONE? If it is not, the installer will report the “Invalid NetBean/Sun ONE home directory” error.
Regards,
Antony.
