Somehow on my diagram all the flow labels that I’ve carefully added to the outputs of my gateways have disappeared. In the example below, the flow has the label “Yes” when you double click it, but when you then deselect the flow, the label disappears. Where have these labels gone? How do I get them back?
Would it be you have set the message to not show the caption by default? You can right click on the message and select Presentation Option and find it under Show Name.
[quote=rowan.bradley]Somehow on my diagram all the flow labels that I’ve carefully added to the outputs of my gateways have disappeared. In the example below, the flow has the label “Yes” when you double click it, but when you then deselect the flow, the label disappears. Where have these labels gone? How do I get them back?
[quote=Rain]Would it be you have set the message to not show the caption by default?[/quote]I have not done this intentionally, but I suppose I may have done it inadvertently while trying to something else. Next time it happens I’ll check this.
