I originally installed Community Edition but I think I might be more suited to the Standard Edition so I installed that version instead.
As part of my evaluation I tried setting up Eclipse integration but when I try to start VP from within Eclipse by selecting “Open Visual Paradigm” I get an error:
“Please start the standalone Visual Paradigm and review the license. After that, restart IDE.”
followed by:
“Cannot start Visual Paradigm CE.”
(Note CE and not SE)
Is it thinking I still have Community Edition or is this a limitation of the evaluation? If it’s the former, how can I fix it? If it’s the latter, how am I supposed to evaluate if the full features are not available?
Thank you for your post. Did you uninstall the integration or the entire Visual Paradigm Community Edition installation before installing Standard Edition? If not, please have a try. You can uninstall the integration or the entire product installation by running the uninstall program in %Visual Paradigm Install Dir%\uninstaller. After that, re-install the integration with Eclipse under the product installation of the Standard Edition.
I have the same problem.
First I installed Community Edition, but code synchronization supported in Professional Edition or above.
When I uninstal Visual Paradigm Community Edition and install Professional, “Open Visual Paradigm” in NetBeans and Eclipse and get an error:
uninstal Visual Paradigm does not help.
before I installed Professional Edition on another computer it works, but in this case, when the first was set Community Edition error is presented.
