After removing the Emotion row from the CJ diagram, it is not possible to re-insert it
Have you already elaborated the map copying function? Currently, its lack is very troublesome.
greetings
Mariusz
Thank you for your enquiry. We are currently investigating the issue.
Hi Mariusz,
The problem has been fixed, you try again now.
It’s still doesn’t work. Would I need to install the patch to check the improved functionality? We have a server version.
Hi MariusMi,
May I know what is the version of VP Server you using?
Rain Wong
Hello
We have 20190430ch
Best regards
Mariusz
The 20190430ch actually is the build number but not the version number (which should be something like 15.0, 15.1, 15.2, etc…). Anyway if you using the v15.2 server then please update your server with the following patch package for fixing this problem.
https://files2.visual-paradigm.com/index.php/s/VYfDfwO03OFfgBI
Feel free to contact me for any questions and wish you have a good day!
Rain Wong
