I need to find out the difference in days between two dates, so is there a method where I can pass two Date instances and then it will return the difference as an int? Thanks
Hi Mike,
I assume you are using the java.util.Date class.
From the API, there is a method compareTo(Date anotherDate);
Usage:
int i = firstDateObject.compareTo(secondDateObject);
Hope that helps. By the way, most of the stuff in the Date class is depricated and it is preferred to use the class Calendar instead.
Martyn
Hi Martyn,
Thanks for the reply. I managed to get round my problem by restructuring the algorithm.
I wasn’t too sure whether the compareTo function in java.util.Date returned the days either side of the firstDateObject e.g. -2 if first date was two days before the second, or if it worked like the some of the other compareTo fuctions only returning -1 if the first date is less than the second, 0 if there equal, or 1 if the first date is greater than the second?
thanks
Mike
Mike Peter,
As u said,compareTo() returns only -1,0,-1
U can use getDate() method instead of compareTo() to get this job done.
Date d1=new Date(); //Wed May 19 23:40:16 GMT+05:30 2004
int date1=d1.getDate(); // date1=19
Date d2=new Date();
d2.setDate(25);
int date2=d2.getDate(); //date2=25
System.out.println(date2-date1); //result=6
senthil
